spyderyderjim
Hi All,
1. Adjusting 2015/16 F3, T & Ltd Drive Belt tension lower to 180# on Krikit gauge will reduce vibration level.
2. (F3 stock belt specs are too high); that is why so many F3 owners after several thousand miles notice less belt vibs because of belt settling to a lower tension.
3. 2015 F3 owners need to install stiffer rear shock/spring to raise rear ride height; (a rear sag height of 2-3" when sitting is too much, putting more tension on drive belt).
4. Installing a Elka rear shock with stiffer spring will raise rear ride height back up to normal 1" rear sag.
(I have a Elka rear shock with Hyperco 800# single spring 8" long x 2.25 ID), 1" sag rear ride height).
(http://www.hypercoils.com/conventional-springs). (Hpyerco 650-800# spring driver only; 900# spring depending on if you ride double all the time).
(2015 F3 stock rear shock spring is 360#).
5. 2016 F3 T & Ltd owners just need to put more air 30-90# in rear air bladder to raise rear ride height to about 1" rear sag.
6. F3 Vibration blog June 2015 post #46 by sledman gives excellent info on lowering drive belt vibrations.
7. I don't have drive belt vibs on MY 2015 F3S SE6 Touring mod Spyder with 19,000 miles riding experience, 180# Krikit reading, F3S on the ground.
Enjoy your rydes.
Jim
Enjoy your rydes.
Jim
