F3 Idler Pulley install video
Lamont, you're a good man.......but we all knew that. Not even one of your products and you still went to the trouble of making an install video. Thanks very much :thumbup::firstplace:
Idler
Thanks that was most helpful. Really liked your use of the screw diver and hole punch.
it was useful to see the tolerances and alignment to the belt.
Thanks again
Really good video! Quick couple of questions;
1. Should the belt alignment be adjusted before installation?
2. How will this effect the belt tensions? Any changes in procedure when adjusting tension?
Thanks once again....
You always keep us up to date on the new items Your and others ...:firstplace:
Install
Installed mine today..took about 30min.. Then.....took it for a ride...up to 70mph.. I am very very pleased..almost smooth as silk..Will make for some great long rides..
Where did you find one? Dealer here acts like I'm crazy. Is there a link or something?
thanks
got mine today from power sports no bolts does any one know what they are
There are two 13mm bolts that are already on the F3 holding the rear foot pegs. Those two bolts are also re-used to install the idler arm bracket that sits on top of the existing hardware and you just need to Loctite down the two 13mm bolts when you put them back in to install the idler pulley.
Do NOT use Loctite only use blue thread lock
