Has anyone pulled the splash guards off? ....the ones mounted on the frame held in
with (3) torx and the (1) Push-pin? I pulled those all out but the unit did not "split"
apart.
It looks as if the front (facing the tire) and under is one part, then top-rear is
another. It clearly is apart in the rear where the torx were but did not want to
force something if its snapped in on the front side?
apart.
