spydermanstever
Could someone provide me with the specs (x) for the 2015 Spyder F3 :
Belt tension : (x) N +/- (x) N
Belt Mass : (x) g/m
Belt Width : (x) mm/R
Belt Span : (x) mm
I only have the BRP shop manual for my RT Limited that gives the above specs for the RT, but I know the specs are different for the F3. I am using the Gates Sonic Belt Tension Meter, and need to input the latter 3 values above. I am also comparing values obtained by the Krikit to see the differences.
Thank you.
Belt Mass : (x) g/m
Belt Span : (x) mm
Thank you.
