Exhaust
Jharpo
Does anyone know if the Yoshimura R-77 exhaust will fit the ST? I've emailed Yoshimura, but they haven't responded yet.
I just heard back from Yoshimura. They don't know. Have not gotten ahold a ST to measure it out.
Don't know..!!
both the 2013's and the R-77 are new. The R-77 was offered for the RT's but I don't know if it will work on the ST. If the part number (exhaust) for the RT and ST are the same it should..!!:dontknow:
Not certain, but start by checking the style of piping you have. If your cat is located right under the pegs in front of the tire, and you have the 2 bolt flange right there, it is very possible. I have one coming, it was listed as being for a 2013 rs, but I am hoping it will also work on my 12 rts. It shows having the same flange, so I am hoping. The price was too good not to buy it and worth a little cobbling to make fit.
Hi, I also have the ST I have 2 brothers and is working just fine, great sound got it from revzilla.com when I called I talk to Jon Santos his ext is 140, I had to do some adjustments to the pipe, Meineke and they did it for me. hope this is helpful.
exhaust
it bolts up but you have to modify the bracket you hang it from. It works fine on my st but is almost as quiet as stock
