exhaust options
ibanez210
i have a 2010 spyder rs that im investigating changing. anywhere that i can hear examples of the sounds? anyone have any suggestions as to what i should get? i like the two brothers dual carbon fiber but its pretty pricey.
If you go to you tube you will find lot of different ones but still not same as hearing it in person the dual two brothers is LOUD.
Hard to say..!!
you tube has the most but still hard to tell. We have a hindle which is on the low side of the noise curve. Need to find others with pipes to hear. Some come with removable baffles..good hunting..!! :dontknow:
Leo Vince
After running a Two Bros for quite some time, I switched to the Leo Vince (Baffle removed) and am much happier with it. I had the Two Bros re-riveted a couple of times and even with loctite the last time, they eventually vibrated out. The Leo Vince is definitely pricier, but gave me the performance and throaty sound I wanted, and without the rivets. Also...works with or without a fuel management system (as does the two bros).
HMF
HMF is the best bang for the buck out there. great sound. under 300.
the TB duals are extremely loud.
