I installed the Hindle on my SE5 (only 155 miles so far). Love the look and the extra torque but not the sound, my problem is at where the bolt is on the collar there is a exhaust leak. I check and checked to make sure it was on straight and all the way and also made sure it is torque as the instructions says even took it off and put back stock and no exhaust leak from stock. In the instructions it says to remove the seal when you take off the stock but no where it says to re-use or to get a new one for the Hindle and it does not fit with the Hindle anyway, I even tried to tighten the collar a bit more but still get the exhaust leak even after running for a over 30 min it still leaks. I do not know what else to do and not sure if this is normal or not but I am not very comfortable with having an exhaust leak, any others out there have or had this problem and what did you do to fix it.
Roger C
[email protected]
Roger C
[email protected]
