Exhaust flex joints...
ataDude
Mod Maniac
... I'm getting ready to build a new TWO SIDED exhaust system from the headers down using some super-secret, stock Japanese superbike mufflers. I won't be welding too much on these as they are aluminum and titanium (which match my knee and pelvis hardware). :D
I'm thinking of eliminating the slip-joint gaskets (the ones we lose) and replacing with stainless flex joints.
Any comments? Experiences? Flex joint brands which are good?
I just can't turn loose of the exhaust thingy. It's an illness. :yikes:
Hopefully it sees the correct exhaust flow vs rpm/throttle position
Or, I can always just install it in one down-pipe for the input. There's several motors that do this. Or, I can even install the Evoluzione O2 sensor eliminator, which I also have "in stock".
In any case, I'm still at square one. The pipes arrived yesterday... damaged by FedX. eBay seller is cooperating, though. :yikes:
Thanks for the thoughts, Trouble Maker #1! :clap:
Shameless bump for comments on these:
I'm certainly curious to see how they work out for you. I don't relish the thought of having to change exhaust gaskets every 4,000 to 6,000 miles.
Changing exhaust gaskets every 4000-6000 miles wouldn't be too bad as long as the location was where you could do it on the fly.. (ie: not remove panels, easy to get to, maybe even while riding!!!!!;))
Just kidding on the while riding comment.. I think it will work. Plus look great!!
