I have 2013 st-s and the heat bars usually stay at 5-6. Today it was 48 degrees when I went for a ride and within 30 minutes the heat was coming out of the seat and right side so much I needed to move around on the seat. The fan was coming on and off while riding in below 50 degrees. It was also very windy on the highway.How many bars are people showing who are having big heat issues on their ST's. I show any ware from 3 to 5 depending on where I am driving. It feels warm but not unbearable. Just curious if some people are showing more than 5.
That is typical. If the engine overheats you will get a warning...and probably limp mode. If your fan isn't running frequently except in triple digit temperatures or stop-n-go traffic, your Spyder is normal.Not to hijack your thread with my RT-S comment, but I don't have bars, but rather a temperature gauge. My gauge regularly runs between half and a little below the 2/3 mark (with 2/3 being red). Is that normal for the RT-S's out there?
What would you consider frequently for the fan? I just took the Blue Recluse out for a cool 74 degree night time ride and I heard the fan come on many times (Didn't realize the fan being on so much before this particular ride, as tonight I drove without a helmet and I can hear the fan). I also wore shorts and sneakers and felt a lot of heat on my left ankle. I haven't noticed these things before. It's only less than two months old and they said they did the recall before it was handed over to me. Anything to worry about? Should I just wait to see what happens next summer when it's 112 degrees outside here?
Thanks for any feedback.
Frequently depends on the speed, the ambient temperature, and specifically the engine temperature. At 74 degrees I would not expect the fan to come on at all unless you were riding slowly or in stop-n-go traffic. At about 5+ to 6 bars or marks on the gauge it will then come on in order to do its job. The radiator discharge blows out on the right side...it should not affect your left foot unless you have cut out some panels. The left side heat is more likely from the exhaust pipe. Some radiated heat there is normal. Shorts and sneakers are not appropriate riding wear, so if you choose to wear them, expect to feel some heat, especially on the left side near the exhaust.
Sitting still the fan will come on in just a few minutes...even at temperatures below 50. Running around at speeds below 35 can cause it to cycle periodically, especially in warm weather. These would both be considered to be normal. Heat near the right foot, especially with the fan running, would be normal (although maybe not pleasant or even tolerable). Heat on the left side may or may not be normal. There is a certain amount from the exhaust pipe, but for most riders with appropriate gear, it is seldom objectionable. So much heat on the center panel that you cannot touch it is not normal, IMO. Some 2013 ST's seems to be plagued by excessive heat build-up in this area, and the RT's to some extent too (but less noticeable due to the glove box. Some 2013s exhibit more heat at the center panel and seat than others, just as some have melted master cylinders and evap canisters and others have not.Thanks, Scotty. Now I could ask what you consider "slow", but I won't. I think a few times when the fan was on I was just sitting idle in a parking lot looking at all the options on the digital display. But the other times I was probably going slow, maybe around 35 or so. I'll just start paying more attention to it. Being in Arizona with our days still around 90, I might be in shorts and just get the urge to hop on the Blue Recluse for a quick ride around town without an outfit change. So according to what you are saying, maybe the heat I'm feeling at my right ankle is just "normal" heat. Good to know. My gas cap never gets so hot where I can't touch it, but the black "bar" (lack for better words) above that going down the center of the bike under the seat does get so hot more towards the top I can't leave my hand on it for more than a few seconds. And I do get the most heat around each side of the glove box . One of these days I will start get up the guts to start "wrapping" some of the internal components on my own. I guess until Summer here, I have just been hoping in the back of my mind that BRP will come out with a "fix", bandaid, or volunteer to absorb some of the cost of providing these "aftermarket" mods we seem to be having to do to minimize the heat we are experiencing (yeah, likely chance I know). Thanks for your knowledgeable replies to this newbie, and sorry once again to the thread owner for me hijacking your thread with my questions. Next time I will start my own
The thermostat doesn't open until 3. 3-5 is pretty normal. Each instrument will read a little differently, too. There is no need to worry unless the machine overheats and shows a warning light, the fan runs frequently in cool temperatures, the fan doesn't run with the gauge at 6 or above, the Spyder suddenly starts running well well above where it normally does with no change in ambient temperatures, or doesn't heat past one bar no matter what (except maybe in Minnesota in the winter). It is because people fret and worry needlessly about the "number of marks" on an unlabeled gauge that idiot lights were invented. nojokeWow, still running 5 bars in those low outside temps?
I wonder if a lower thermostat is in order?
it would be nice to know what actual temp each bar represents.
