Evoluzione Sway Bar install question
WackyDan
Installed the sway bar. Took all of ten minutes as my trunk is already off.
Question: The stock sway bar has two plastic stops that sit outboard of each frame clamp. These have a metal sleeve for the bolt and the stock sway bar is indented for that sleeve.
I assume that you don't reuse those stops as there is really no good way to use them on the Evoluzione Sway Bar to begin with... Or am I wrong? They are not mentioned in the instructions.
