cjackg
Pretty tough to get an accurate measurement or compare unless you have both on a bench. I did a close comparison before I installed mine and the only difference was the Evo bar is shorter.Evoluzione is out of business. They didn't make the bars as they are made on the east coast.
I have dealt with these guys on other bars & was talking with the main guy about other things
& brought up the bar on my 2012 Rt. I gave him the specks on it to see what rate he came up
with which was 500lb the same as i had rated it. At this point he told me they had been making
bars for Evo for the spyders. There is a straight bar & a bar with 2 curves which he could not
find at the time so we didn't worry about the rate on it. cjackg & zippe will you guys check the
bar size,arm length & the length of the old & new bars & post this? My RT bar is.625 thick 15 "
in effective length & the arm length is 43/4" Effective length will be the bar length measured
between the arms where they bend to turn out.Arm length will be from the front back to the bolt
hole center.
i believe MMcc has one for sale.
