Evap canister
900Dave
I want to relocate my evap canister. Does anyone have any picyures of where to put it. My stock airbox has been replaced with JT's air intake so lots of room up there now. Just like to know the best location to put it.
I'd try and mount it as high as possible...
Put a good loop of vent hose well-above the highest point on the fuel tank. That might help to keep any fuel from getting sloshed down into the canister. :thumbup:
I moved mine on a '13 ST to where the factory put them in '14. I posted pics a few months back.
attachment.php
The bracket I made to hold the canister.
attachment.php
attachment.php
attachment.php
Not sure of the location from this pic. I did look up your other posts on this and it sounds like the relocation did not help very much. I think I will just remove it all together.
EXAC CAN MOVE
To what purpose are you doing this .............I solved the " GAS INTO THE CAN PROBLEM " with a simple loop in the hose from the gas tank to the evac can.........Never got a single drop of gas in the can....and never had any smells either ...............took all of 10 minutes ......Mike :thumbup:
This morning I decided to do a complete canister delete. $11.00 in parts and about a half hour. I decided to route my vent line up as high as possible. In the first pic the line that came off the canister I routed up under the tupperware. My vent line is now about 8 inches higher than the top of the gas tank. I then added a cheap fuel filter and put an additional 3-1/2 feet of fuel line and routed it front and down next to the antifreeze overflow.
attachment.php
attachment.php
The best place is the trash can, IMHO.
