:dg1::yes:It sounds interesting... :thumbup:
...But if the conversion over to it, is that involved; I think that I'll continue to "dance with the Girl that I brought to the Prom."
I'm using it In my ktm dirt bike and it work very well the process to switch over isn't that bad you have to put there pre mix in first which absorbs any water left in the system all arguements over Evans seem to revolve around it's cooling capacity ,the big advantage I see is that it doesn't boil which causes you lose coolant then you boil easier which is what my ktm would do in slow trail use with no fan ,but before everyone jumps all over me with arguements about less cooling capacity consider the biggest benifits of Evans is that water is corrosive and causing all kinds of slow death inside from crust to hardening of hoses and rubber parts plus you don't have to change it like regular anti freeze the arguements of having to carry different coolant isn't a problem since it doesn't boil over causing coolant loss plus you can put water with it in an emergency it just lowers the boiling point the stuff worksif you do convert let us know how it works. The conversion process is a bit complicated and the idea of having to carry their product with me on trips kinda keeps me away. I use blends and water coolant mixtures so I can always find something on the backroads should I need...has good write up and looks like a great product and might use it if I stayed on the main roads...:thumbup:
My spyder never boils ktm s are race bikes with no fans and are designed to to be moving when ridden slow and technical they will over heat and boil I put a fan kit on ran it then went to Evans also the fan kicks on less with the Evans the argument against Evans always revolves around the fact that straight water out cools antifreeze but what happens with the higher boiling point you don't get the little air bubbles on the cylinder walls that don't transfer heat as well the higher boiling point stops this and transfers the heat better ,the big trucks are sometimes running Evans and it is paying off because the fans kick on less and increases mileage a fraction and add to the fact that you don't have to drain and flush add to the savings,the extra cost is very minor in something that hold a few quarts like my dirt bike ,as far as the oem's not using it they look for every penny to cut and they want to use something you can buy any where if you don't think they pinch penny's just look at our fine tires and vacuum hoses they put on our spyders,it's water that's corrosive not the anti freeze if you don't believe me look and touch you corky in your toilet tank it's rubber and is rotting every day or look at the rubber in your faucet stemsIf your engine is boiling coolant, the anti-freeze is not your problem. It should not boil.
My spyder never boils the coolant. Even my 2013 RT as hot as it was when new, NEVER boiled over the coolant.
Water mixed with appropriate antifreeze is NOT corrosive and in fact does protect metals from corrosion very well. It does wear out in time. The Evans does last longer but is quite expensive and does make engines run hotter if they were already having cooling issues.
Evans is a great product for vehicles in a collection or museum that need to go long periods without use or maintenance. its not a great solution for performance or normal use vehicles. If it were, at least SOME OEMs would be using it. They do not because it significantly increases the size requirement of the cooling system. (on an existing system it reduces its capacity).
My ktm has no problem boiling with Evans and as I said the fan kicks on much less now air bubbles at boiling isn't just a diesel thing look at the pan on your stove as the water boils air bubbles everywhere ,I don't know about your water but I've tried every kind of synthetic flapper they make in my water tanks and they still go bad well before 10 years ask the radiator guys and they will tell you that the new anti freeze breaks down and needs changed every 2 years I'll take much longer changes any time everyone use what they want but I can tell you from personal experience that Evans does what they claim and it's worksNewer plumbing fixtures use EPDM rubber for seals and ceramic seats....they last MANY years. Same for high quality tank valves. But that has nothing to do with galvanic corrosion set up by water. EPDM rubber is also why radiator hoses now routinely last 10 yrs or 100,000 miles rather than just a few years as they did in the distant past. Has nothing to do with corossion. That was chemical breakdown of the rubber.
All major antifreeze and even just water wetter inhibit the corrosion for a time. As I said, Evans does this longer...not forever but longer.
localized boiling at cylinder walls is called cavitation and yes some diesel engines do indeed have a problem with it. However its related to the relatively thin walls and very high compression ratios, not strictly temperature. It can happen in the water pumps as well. As long as the cooling system operates well below the boiling point, the cylinder wall and head temps should come no were close to boiling point or cavitation.
The problems with your KTM are because you are using it in ways the cooling system was not designed for. This is NOT the case for Spyders or most all street cars.
the OP ask if anyone has tried Evans I responded and said I have and with good results and was able to compare to regular anti freeze the fan kicks on much less now I'm not sure how those who haven't used it can say they know the results that's fine I'm not a chemist I just see something work and higher boiling point means less pressure on the system and hoses,I've repaired appliances for 30 years and what ever you call it water takes it's toll on "rubber" parts from the inside get an old washer fill hose and cut it open and you will see it hard and brittle on the inside don't know if corrosive is the right word for it but the water does something to the inside that the air isn't doing to the outsideQuit buying cheap made in china crap from home depot and you can find good quality parts. Try OEM parts from Sloan or American Standard. The tank valves in our two bathroom toilets are Sloan, were OEM originals when installed in 2003 during our house rebuild. Still there and work fine. Used to replace plumbing parts nearly every year at our vacation house in Colorado, finally bought good parts a few years ago and it all stopped.
Still, this has NOTHING to do with corrosion.
Glad the evans works for you. Does nothing I need or would benefit from and would prove a detriment in several. Nor most other Spyder owners. The OEM coolant used in the Spyders and most modern vehicles has no trouble lasting 5 years with NO corrosion in the system. Often can go much longer if its tested annually.
Has anyone used Evans Waterless Coolant in their Spyder ?
It has a higher boiling point and won't clog up your cooling
system with corrosion like water based coolant and it's good
for the life of the vehicle.
How in the world did I just reply to an almost 3 yr old thread!! ( it came up in a search....) Sorry!
