Error code p0172 after stage 2 flash
jjpgator
Anybody have any error codes pop after stage 2 flash?. I have a 2018 F3s. Did stage 2 flash, cat delete, and K&N air filter. After about a week, check engine light came on and shows code p0172. Any help would be greatly appreciated.
P0172 Possible Causes
What does this mean?
Faulty Front Heated Oxygen Sensor
Faulty Spark Plugs
Faulty Mass Air Flow (MAF) sensor
Exhaust Gas Leaks
Ignition Misfiring
Incorrect Fuel Pressure
Faulty Fuel Injectors
I'm guessing Monster/Wick-It is going to have to scan/reflash your ECU. Dealer won't help with your flash. Kind of a PIA :( Good luck
It's been 12 days. You have contacted the the place that did the flash, haven't you ??
Yes. I have sent 2 emails and no response. I put the cat back on and changed the O2 sensor. After about 2 weeks the check engine light went off.
