Went out to start the spyder yesterday and it had a dead battery. Planned on using my battery charger but when applying the cables the charger pegged and then shut off immediately. Rechecked to make sure all connections were correct and tried again....same results. I then figured I had a bad battery due to shorted cells . After a lot of head scratching reading the manual on how to get to the battery terminals themselves I got help from Nancys Toys......Thank you ......and then finding Lamonts video on removing panels ....Thanks Lamont ....I finally ended up getting everything off . Once you do it it isn't all that bad but definitely not on top of things to do list.
Disconnected positive terminals at battery and gave the charger test again , charger performed as it should. At this point a bad battery was ruled out and pointed to something going on with the electrical somewhere in the bike itself. I charged the bike all night and went out this morning to check it , battery fully charged. The key was not in the bike . As soon as I touched the terminals to the bike the engine turned over just like hitting the starter switch . Double checked that I didn't have the key in and tried again....same results. Put key in and operated it to make sure that it was in the proper position ( off ) and removed it again and tried the terminal again with same result. Quit trying at this point because there is something going on inside which means I now have to take it to the dealer . Not to confident with my dealer mechanic since I called him yesterday and he said you couldn't jump start it....per BRP , and to charge it you needed to remove the battery from the bike....again per BRP. I asked him why then did they give instuctions on how to do it in the owners manual and he said he didn't know they did.....so much for mechanic schooling .
Has anyone else experienced this problem or have any ideas on what is going on ? I know there are components energized all the time but the starting system def shouldn't be one of them , especially with the key removed.
