Trying to find out whether ryker has a temperature sensor/valve which keeps engine temperature in optimum zone. Problem: engine temperature doesn't increase during the ride in cold conditions. If I will stop and keeps it for 1-2 mins turned on, temp is going up showing that it is wormed up. However once I will start driving fast (above 30 mph) temperature immediately goes down. I can basically see that temperature bars showing it until I will see just 1 "point" on the screen. No idea whether it is normal or not.
I thought it should be like on the car: temp is going up and stays flat until the end of the journey.
Could you please check your rykers engine temperature?
