Engine Light and ABS Fault Comes On
Bert715
2010 RT start is up cold and goes about 1/2 block and engine light comes on and ABS Brake Fault light comes and it goes into limp mode and then if you go another 1/2 block it all clears and drives fine after that. Anyone else having this problem?
I had this exact same thing, except i think the cluster turned orange and said "BRAKE FAILURE", the dealership said that the brakes needed to be replaced, so I had them do it and it hasn't come back on for the last 500 miles now. So it might be just an added safety feature to get them changed before you need them.
