Engine Fault code P0171
rworell
Got this code today after I had to brake hard for a car pulling out in front of me. Bike ran great before and after the fault. Code possibly not true? Can I clear it??
thanks
Rich
BRAKE CODE
If it cleared quickly , I'm guessing your fluid may be on the Low side of full .... and the surge ( from hard braking ) cause dit to flash a code ..... The sensor for the amount of brake fluid is imho overly sensitive to the amount needed in the container ..... Mike :thumbup:
P0171
P0171 is a engine lean code in the automobile world. better have it looked at before engine issues
Let's see....
The code you mention is for bank one running lean. It also talks about the ecm and computer communicating with the vss. Have had this before for similar reason but once you shut down and remove the key letting the computers reset it clears and will be stored. I think sudden movements mess with the computers minds..:roflblack:
It sounds more like a sensor issue than a computer issue. The computer is just responding to what the sensors send. Technicality I know but attending to the sensor and its asset is probably a better first step than trying to figure out the computer.
