jimcrom
So I am traveling down the highway doing 70 mph with no problems for over 40 minutes when all of a sudden the engine just cut out and died. I pulled off on the shoulder and coasted down to about 35 mph and let out the clutch, the bike started back up and I continued down the road. There were no codes showing up, there was no noise or anything other than it shutting off. I had filled up at the usual spot, there was no change in the spark plugs or any other mechanical parts. This happened one other time about one month ago in the same kind of circumstances. I called the dealer and asked if they knew what the problem might be. (I know it is hard to diagnose for 140 miles away)
Does anyone have any ideas, suggestions. The spyder has 37,000 miles, the battery had been changed three months ago, all the recalls had been done. The engine has been running smooth. I was able to turn around and drive home with no incidents.
