Baja Ron post a pic for the Ryker & cost. Please
Do you make them for the can am stock sway bar. Just the end links. If not you should.
I was curious about the same thing. I was thinking of adding them to my stock Rally sway bar but I am hesitant because I'm not sure if there are any benefits.
Cost of the Baja Ron end links that will work with the BRP sway bar upgrade kit.Yes, the end links I have for the Ryker work perfectly with the stock bar. And they do make a difference. But I do want to be sure people understand that though the stock BRP upgrade bar kit install is an extremely difficult, time consuming and frustrating process. The BajaRon bar kit for the Ryker is quite easy to install and takes most people about 1 hour. The worst part of this install has to to with the 4 nuts/bolts that secure the bushing blocks. 2 of the 4 bolts are in a bit of a tight spot. But with tools that most of us have, they are not all that hard to deal with. The rest of the install is pretty straight forward.
If anyone has any questions about this kit or anything else I carry. Let me know. Glad to help, explain or clear up whatever questions you might have.
Link set is $69.00 delivered...
........Has anyone broken the OEM sway Bar end links?
Darrell
How important are the reinforced end links versus the stock OEM? I have your Sway Bar with OEM end links--hasn't been any problem so far--7000 mi later. Has anyone broken the OEM sway Bar end links?
Darrell
