Not a recall, but a service bulletin, affecting a large range of serial numbers and models. If you have parking brake issues, they are supposed to replace the revised part. Only happens to most folks if they ask. I had to ask before they even would order the part.Ok I don't know anything about this, this is the first I've heard. Is there a recall from BRP or what? Someone please fill me in.:dontknow:
mine goes in on saturday how long did it take them to replace.
The cable can only compensate for a certain amount of wear though....once it reaches the end of it's adjustment, the lever which the cable is attached to will have to be removed and re-positioned on the splined shaft....also quite easy to do. :thumbup:Several weeks back my parking brake wouldn't disengage completely. The symptom was the idiot light on the dash wouldn't turn off. Gently kicking the pedal inward to unstick it did the trick, short term. Spraying silicone on the spring, behind the pedal, permanently fixed it (lubed it up.)
Next problem was the brake cable became loose where it wouldn't hold; bike would roll. It's easy to tighten up.
(1) Manual instructions state you should lift the rear tire; I did.
(2) Go to the back of the Spyder, right side of the rear tire.
(3) Find where the brake cable connects to the spring.
(4) Loosen the nuts on both sides of the cable.
(5) Move the left-most nut toward the end of the cable (that is, unscrew it, it will move toward the back of the Spyder).
(6) Tighten the right-most nut (tightening will move the nut toward he back of the Sptder.)
(7) Test parking brake.
(8) If it still doesn't hold, repeat steps 3-6.
(9) Drop the Spyder back to the ground.
... geez, took me longer to write this than to actually do it![]()
-Scotty
That explains why SE5s are first in line.This was actually considered a recall on SE5's and a service bulletin for SM5's. SE5's require the parking brake were SM5's don't require its just recomended.
