Emergency brake dilemma
need to know what type of Spyder:spyder2: you have 1st..Then we know what we lookin at:banghead:
Guessing he has an RT since that is where he posted but the parking brake isn't an emergency brake so hard to be sure. I had to get used to just poking the parking brake rocker button. If you hold it, it will not disengage. OldFTS, you might want to add a signature that tells folks what type Spyder you own. Saves from going into 20 questions or ASSumption mode! Cheers. wg
parking brake
We have a 2012 RT Limited.
The brake cable is operated by an electric servo that is located under the right hand side of the tupperware.
There is a fairly large spool the cable is spun on to take up the cable.
Sometimes this cable comes off the spool and can jam either in the on or off position.
I agree with the previous comment :thumbup: :agree:
Agree..!!
:agree: if it is presently stuck. If it is intermitant you may have something jamming up. The fuse mentioned by billybovine is a first step then move on to the cable to the servo and then on to the rear caliper wher the cable operates the parking brake...:dontknow:
When we start the bike the emergency brake will not disengage. Any suggestions? Thanks.
I am having the same problem. 2012 RT SE5. Pressing the release switch does nothing. Light continues to flash and brake doesn't release. NOTE! I just replaced the battery. I don't know how that could affect it though. When I press the switch, the image of the bike appears (orange) in the bottom center of the display.
I had the same problem with my 2015 RTL. Dealer said he replaced the brake motor. No more problems. Hope this helps.
