Bad Dog6
Elka's arrived yesterday afternoon so I spent the evening reading up on them and searching the site for tips. Got up at 6 am this morning and went to the shop ( Supposed to be over 100 deg. F today so wanted to work while it was still cool.)
Jacked up the RT under the front till the wheels where about 1/2 in. off the ground. Started on the Right side as everyone said the left was a bugger. Removed both nuts and then the bottom bolt. Jacked the bike up till the bottom of the shock was clear of the mount then pulled the top bolt. Jacked the bike a little higher to facilitate removing the shock. Slid the Elka into place and started the top bolt and put the nut on loosely. lowered the jack while, at the same time, guiding the lower shock mount into position. Installed the bolt and nut and torqued both upper and lower to 35 ft. lbs. (I am an old Aircraft Mechanic so Torque is a habit for me.)
The left side was a little different and much easier than the right side for one reason. I read on the site that those who installed Elkas, if they had to do it over again, they would cut a 3/8's notch in the air tube directly across from the head of the top Shock mount bolt. ( it is easy to find where to cut. After removing the bottom nut and bolt and the top nut slide the top mount bolt out and the bolt head will hit the spot that you need to notch.) After notching the air tube and removing the top mount bolt and shock, I slide the Elka into place and installed the top bolt and nut and lowered the bike till the bottom hole was in alignment and installed the bottom bolt and nut and torqued both to 35 ft lbs. DONE. The whole job took about 2 hours start to finish. Note NO Tupperware removed.
Took the Spyder on a 10 mile test ride on a twisty road and WOW. Easily added 20 mph to all the corners and was rock steady on the straight. A different bike. never once felt I was on the edge of "Nannyville"
I purchased the Shocks from Cowtown but did not talk to Len. The person I talked to didn't ask any questions about weight just asked my percent of 2 up riding. The shocks came set to 21 clicks. I weigh 205 and the wife about 130lbs. Does 21 clicks sound correct for that combination? Also, I have the stage 1 + I think and there is a schrader valve on the top of the shock. I assume that is for Nitrogen and is not a customer function to mess with. The instructions I received make no mention of the valve. Final question. When they say the shock is set at "21 clicks" When you make that adjustment do you actually feel a click OR?
Anyway, overall I am a very happy camper. Thanks to all the trail blazers here on Spyder Lovers and to Cowtown. :yes::yes:
