Elka stage 1 preload question.
JCSMOKE
I have the shocks installed and am about to install the sway bar and re-locators. The question is: How do, and how much do you change the preload on the shocks. I am sure someone has posted something about this but I have found nothing in searching. Thanks for the help.
Less Elka shock preload
Give Len a call at Pit Bull Powersports Springfield, Mo 417-863-1418; he knows how to set up Elka shocks for his relocators on Spyders. (loosen set screw with hex allen wrench in Elka shock kit, & turn shock collar spring preload a couple of turns (backing off), extending shock spring length). Maybe you can post results after your preload adjustment. Jim
