Elka shocks compatabilty
TroyboyRn
Just wondered if anyone knows if the stage 2 elka shocks of my 2010 rt were compatible with the 2016 f3 limited. I am betting not but they do look very similar in size.
The are the f5.8x254. Any thoughts would be appreciated
Thanks in advance
Don't know. ..!!
But if they are the same length and with the adjustment range they should work. Could be a bit stiff but adjustments could get you what you want. :dontknow: a call to Elka or check with our sponsor here could clear this up for you...:thumbup:
Thanks in advance
Elka's part numbers are quite different for the two applications. I assume you are talking about the front shocks
I dont think so
The front suspension/shocks completely changed in 2013. I am almost certain that your shocks off your 2012 will not fit the F3.
I was wondering myself if my Elka's off my 2013 ST will fit the F3 also. I think they will so I will keep them when I make the trade and do a caparison. If they do not fit I will sell them.
Your best bet is to call Elka and get the part # for the F3.
