johnphipps
Had a slight fender bender 5 weeks ago, took the dealer 4 weeks to get to it. Ever since the accident, i have had electronic problems, mainly, immediately after the accident, the first time I turned on the key the screen was white with colored lines running vertical, waited 2 minutes and turned the key on and, it immediately went into limp mode. I drove the rt home and, had it flat bedded to the nearest dealer. After 4 weeks they finally got to working on it. The tech. said when he went to bring it into the shop the battery was very low, so he put it on the charger overnight. Brought it into the shop the next day and, said the battery was NO good ( battery is less than 2 years old ) so, he cleared all the faults in the computer. Picker it up and, have had the same problems ever since. I has NEVER failed to start since the battery was replaced less than 2 years ago. Even now it starts normally but, still the screen goes goofy several times a day. I am going to put a volt meter on it today and, check the voltage the battery voltage. Anyone have ANY ideas. I would change the battery but, that is a 3 - 4 hour job.
