Many have stated that when hooking up auxiliary electrical equipment (i.e. lights, cooling fans) that they should be powered through a switched relay. My question is this.....if I have an electrical accessory that draws, say 6 amps, do I really need to power it through a switch controlled relay instead of through a switch that is rated at, say 15 amps. In other words what is the benefit of using the switch to control the relay and hence power to the accessory as opposed to just supplying power to the accessory just through the switch alone ?
Thanks in advance.
			Thanks in advance.
