Bootie
I picked up my new RT-SM5 from the Dealer. In checking it out I noticed that my GPS was not charging and upon further inspection I noticed that the GPS connector was not supplying 12V. I check the GPS Fuse, up front, and find that everything is OK there. There seems to be a disconnect between the front fuse and the access at the rear. It looks as though it was miswired at the factory.
Any suggestions for where to look for the problem. Also, what if I run a separate switched 12V line from the front fuse block to the GPS connecter.
If I can't do this, I envision big problems because, warranty repair has to be done at the Dealer which is 300mi, round trip, for me.
Bruce
Bruce
