WackyDan
So today I decided it was time to partially take apart the Spyder to at least get the battery tender hooked up and working.
First... What a PITA. I had to take the mounting rack for the battery side GIVI side case completely off in order to get the tupperware off that length of the bike. Once that was off, I partially pulled the plastic cover on the left side that covers the gas tank... Just to get an idea of where I had room to play.
First, in the picture below - what is it? My motolights are hooked up to it. Is this the best place to pull a 12 volt home run from, or should I go direct to battery. Also of note, I'm going to have my battery tender hooked up to plug directly into one of my powerlets... Should I ensure that specific powerlet is hooked directly to the battery or can it be hooked here? the question marks denote the connection I'm talking about.
Next up... Ground. In the pic below is obviously one the main grounding points..... I can answer my own question by trying, but can I hook the tender up to that or does it have to hook directly to the battery on the neg terminal? This is where I'm planning to hook up the ground home run for my main electrical add ons.
Next up... I ordered some power leads from powerlet. They are in the pic below. Thought they were neat if not expensive, but screw it.
Now that I've taken the spyder partially apart, I'm wondering if it may make more sense to get one of the fuse/relay blocks that some of you use.
The idea of the powerlet cables below was to eliminate a stack of wires screwed onto the 12volt posts, and to route the powerlet terminal block to an area that is easier to work on the spyder. The cables are fused, and come with rubber boots to protect the terminal block. I was thinking of lengthening the powerlet terminal cables, and routing them to just under the "tank hump" for easy access. I think on the one hand, these do the job, are low profile compared to a fancier fuse block. The only thing I see hooked into them is my powerlets in the dash, and in my helibar setup. I'll also be hooking up my DC voltmeter gauge, though that will be switched.
Anyway... You thoughts are highly valued as always. Want to make sure I have all the pieces I need to really start putting it all together during my Christmas vacation.
