Any Batteries + in you area ? A dead cell in a battery will show a full charge but not have the CCA to do anything which is what you probably had. Having a heavy load on a battery kills it and can cause the dead cell. Expect to pay ~$100 for a proper battery remember what happened when you cheaped out on the install. You should have used a relay fuse block many are on the market and a search will help you find the right one. It works by isolating the device from your fuse box except for the very small amperage to engage the relay and then supplies battery voltage to the heater.. It must be hooked up to a powered by key circuit like the trunk charger. Good luck. :thumbup:
What I don't understand from a scientific point of view (once a scientist, always a scientist) is that if you removed of your battery's cables & connected those cables to your car battery: why it did not start ?
Makes no sense at all in view of the fact it started right up with a replacement battery. Your car's battery was also a replacement battery & far more powerful than the one you bought.
Maybe your jumper cables did not make a good enough contact somewhere as a lot of amps are required to start.
I think it's the same reason the lights came on, a mucked up ECM. The ground side of the starter relay actuator coil goes into the ECM. The ECM has to be happy in order to complete the circuit necessary to crank the starter. And from what you've described, for whatever reason the ECM was not happy. To paraphrase an old saying, "If the ECM ain't happy, ain't nobody happy!"I wondered this same thing myself. I tried it several times and the first time it seemed to brighten the gauges but would not start it even with reving my car engine. Attempts after that all it would do is turn on the lights and the fan (also something i dont get). I also tried jumping it direct to the cables from my sport bike and no luck there either (but did not turn on the lights). I guessed that battery was just not enough for it. The new battery i tried was hanging by a thread so once it started i just quickly shut it off and disconnected the battery and returned it. i should have probably checked all systems but the gauges were good and pretty sure i saw the headlights come on. I was afraid the batt was going to fall and take the cables with it.
But, but, but, jump starting is an approved procedure by BRP. Look in the owner's manual. That is why there are the two booster posts under the service cover in the frunk.All motorcycles and I'm including Spyders loosely here, have sensitive electronics. Jump starting one using jump leads from a car is asking for trouble.
I didnt intend to cheap out on the install. I thought i was going the extra mile buy buying the fuse kit as suggested in the instructions or i just would have wired it to the battery, which is what i am going to do now since it has its own switch, except im going to use an SAE to plug into my battery tender pigtail so i can just unplug it and it has a fuse.
I just looked and there is a batteries plus fairly close, i have never seen it but will check it out next time. i had to oder last night to have it here tomorrow and i have free prime shipping with Amazon so it will be here tomorrow with no extra charge. Right at 100 for the Yuasa
It is recommended you do not have the jumper vehicle running. Ignition should be off and you should go through the battery in your machine. Your battery serves as a filter and a great investment is a jumper charger like antigravity for such occasions. A direct hookup to the car battery may send a signal to the computer of an overload...jmo these machines do get querky when the battery is not just right and logic and science don't seem to apply...Hence all the glitches..![]()
That is certainly proven! lol.
Ok so i got the new battery today and hooked everything up and its starts fine. It is however giving me the engine light and the "check DPS system" i seem to remember getting that once before and it just cleared itself. Any thoughts? That is the power steering or something? i did not have any trouble steering it around the neighborhood. I just have this charity ride tomorrow and want to make sure all is well before i take it.
When you buy a battery from Amazon it will usually have the acid in a container...
Mine will. I've got a NAPA 2 amp charger/maintainer. When my Spyder sits for a few days and the battery monitor starts beeping because the voltage has dropped below 12 I plug in the NAPA unit. Overnight, or so, the battery will be back up to full charge. I even recharge a 115 amp hour deep cycle battery with it from a 20% to 30% charge level. Takes close to a week, but it does it. The red LED on it shows active charge. While it's charging the LED stays on. In maintain mode the unit sends about a one second charge about once a minute as evidenced by the LED lighting up that way.Battery Tenders don't "charge"....they maintain the amount of discharge that occurs over time.
There are a lot of batteries that come direct from the factory already filled, the battery the OP ordered from Amazon was one of those shipped filled from the factory. "Factory activated - filled, sealed and charged at the factory". They can be shipped, but are restricted to ground shipment.
...When assembling new bikes for sale the battery is shipped dry.
I know that various makes of "tenders" may have different codes for their indicator lights, but I believe that the yellow light means that the tender is checking the battery, and that the green light means that it is in a maintenance mode, and NOT that the battery is charged.
The one i purchased "Yuasa YTX24HL" is factory filled and charged battery, no acid separate. In fact the Yuasa web site says to only use factory filled and sealed batteries in the spyder because the battery lays on its back and is at an angle and there could be leakage with a fill-able battery.When you buy a battery from Amazon it will usually have the acid in a container in the box with instructions on filling and nuts and bolts and possibly a breather tube. The battery is dry charged when you get it but usually does not have acid in it as it is illegal to ship a filled battery as even a sealed battery can leak or explode. When you fill the battery you let it stand for a while while the plates get saturated and top up to the fill line either with some of the remaining acid or water.
Have a look here;
http://www.atbatt.com/motorcycle-batteries/how-to-fill-and-charge-yuasa-ytx14-bs-motorcycle-battery
The DPS error should go away if everything electrically is OK and there is nothing wrong with the DPS. If it persists you need to get it checked out. It could be something as simple as the steering angle sensor needs to be reset, which is a simple BUDs procedure. Considering all the screwed up actions your computers seem to have gone through I would say that is a real possibility. If than isn't it, then the DPS could be bad. They do crap out. Mine did last year. If it's not covered by warranty fixing it won't be a pleasant experience, unfortunately.EXCEPT the stupid DPS warning wont go away. Could that be the computer/buds whatever just needs to be reset? What happens if the power steering actually does go out does anyone know? Because it did not seem like it was a problem steering it to me.
