Hey All
I really hope i can find some help or someone who has had the same problems,
started about a month ago with me getting on my bike and starting, which of course happened only it did not shift automatically out of gear into neutral, like it normally does when it did start it took a second or two and eventually did go into neutral from alone but not without jeerking forward, now we have been messing around with the battery because this is an error that my mechanic came up with that the voltage was dropping to low during starting and causing electrical circuits to fail, now the other day i was out for a ride and it seemed to react normal only when i stopped a half hour later and shut the machine off i got a rather loud tapping noise from behind the cluster 3 times and then when trying to restart the machine after turning the key the cluster stays blank for a minute and then came back to life and of course started without a problem.
i know this looks like a lot of problems at one time but this has all happened in such a short time that we were not even sure that we corrected the initial probnlem yet and still are not
I
hope that no one out there has had these similar type of problems but if so i would be very happy for any feed back that i can forward to my trusted dealer of choice with whom by the way i am extremely happy with he gives his best effort and is always freindly no matter what the situation
respectfully
Fuller, Harrison
I
respectfully
Fuller, Harrison
