Someone emailed and asked so I thought I'd post it here.
There are two busses on the Spyder
1 the can bus it's standard can bus and let's the VSS talk to the engine/ECM and yaw rate sensors
2 the k bus it's standard obdii and uses kwp 2000 protocol . The ECM talks to the console with it
I wired a odbii cable to the buds connector and I have a obdii protocol analyzer, an elmchip style $100 USB cable connected to it and I'm reading it in matlab
I've isolated steering angle, wheel speed,yaw rates and angles on can so far
I need to go to a dealer and record a buds session so I can talk to it.
I talked to bosche racing and they don't have access to the sypder VSS software so I can't talk to it unless I buy the race setup and it's 6000 euros. I haven't ruled it out completely though
Anyway that's all for now I'll put up a cable diagram and where you can get a cheap analyzer later
