Eddies Spyder RT-S SE5 2010 Model links to mods
eddieshep999
I have carried out several mods to my Spyder RT-S SE5 2010 Model
Here I have posted the Heading + the link where these can be found on SpyderLovers website
The links will supply some photo's and also comments and suggestions made by other members with ref to the Mod posted
hope these help
Spyder RT Bottom-panel-potection-from-boot-marks
http://www.spyderlovers.com/forums/showthread.php?25780-Bottom-panel-potection-from-boot-marks
Spyder RT right-side-grill-covers
htttp://www.spyderlovers.com/forums/showthread.php?25865-right-side-grill-covers&p=292284#post292284
Spyder RT - Gromet fix
http://www.spyderlovers.com/forums/showthread.php?31559-2011-RT-Upper-Left-Panel-Screw-Problem
Spyder RT Panel fIx
http://www.spyderlovers.com/forums/showthread.php?26434-Panel-flew-off&p=297004#post297004
Spyder RT Front Trunk Hinge broken My Fix
http://www.spyderlovers.com/forums/...FRONT-TRUNK-HINGE-PROBLEM&p=341704#post341704
Spyder RT best-way-to-store-hold-your-iPod
http://www.spyderlovers.com/forums/...y-to-store-hold-your-iPod&p=357149#post357149
Sun Shade-Rain-Hood-for-Zumo 660 on RT
http://www.spyderlovers.com/forums/...de-Rain-Hood-for-Zumo-660&p=360222#post360222
Spyder RT – Loose Mirrors My fix
http://www.spyderlovers.com/forums/showthread.php?31701-RT-Mirrors-Loose-My-fix
Fitting Additional Fuse Box to Spyder RT
http://www.spyderlovers.com/forums/showthread.php?32118-Help-Can-you-identify-these-brackets&p=366988#post366
Spyder RT Stainless-Steel-Handlebar-Weights-Spyder-RT-S
http://www.spyderlovers.com/forums/...ts-Spyder-RT-S-2010-Model&p=379356#post379356
Spyder RT – S Mud flap
http://www.spyderlovers.com/forums/showthread.php?33588-Mud-Flap&p=381995#post38199
Spyder RT extra support for seat stops dropping down due to extra weight of Utopia Back rest fitted
http://www.spyderlovers.com/forums/...WN-WHEN-FILLING-UP-MY-FIX&p=383959#post383959
Spyder RT- S Rear trunk light added
http://www.spyderlovers.com/forums/showthread.php?34590-Easy-rear-trunk-light
Touratech lock for Zumo 660 as fitted to Spyder RT -S
http://www.spyderlovers.com/forums/showthread.php?34993-Zumo-660-Lock&p=399216#post399216
Performance Smoke gauges Voltmeter Gauge and Clock fitted to replace OEM Fuel and Temp Gauge
http://www.spyderlovers.com/forums/...ges-mucho-bueno!&p=548156&posted=1#post548156
Spyder RT Track Rod covers
http://www.spyderlovers.com/forums/showthread.php?36334-Track-Rod-Covers-My-Mods
Securing the tool kit under the seat Spyder RT S
http://www.spyderlovers.com/forums/...-Putting-it-back-in-place&p=486749#post486749
Spyder RT Front-Oil-and-Radiator-grills
http://www.spyderlovers.com/forums/...t-Oil-and-Radiator-grills&p=491203#post491203
Spyder RT extaa 12v-power-outlet-on-dash
http://www.spyderlovers.com/forums/showthread.php?42383-12v-power-outlet-on-dash&p=491221#post491221
2 Din Power Sockets fitted to Spyder RT
http://www.spyderlovers.com/forums/showthread.php?47212-Panel-Mounted-Port-Ideas-Needed
Spyder RT – S Bracket-made-for-SPYDERPOPS-Missing-Belt-Guard
http://www.spyderlovers.com/forums/...racket-made-for-SPYDERPOPS-Missing-Belt-Guard
Spyder RT Converting-stock-Spyder-audio-output-to Bluetooth
http://www.spyderlovers.com/forums/...audio-output-to-Bluetooth&p=510235#post510235
Spyder RT – Fitting-Yoshimura-R – 77 S Exhaust Slip-On-Exhaust-Muffler-to-a-Spyder-RT
http://www.spyderlovers.com/forums/...a-R-77-Slip-On-Exhaust-Muffler-to-a-Spyder-RT
Spyder RT - Waterproofing Handlebar Switches, GPS and Ign Switch
http://www.spyderlovers.com/forums/showthread.php?48132-Waterproof&p=566165#post566165
Eddie Sheppard
Reading UK
You've been rather busy! :clap:
Impressive list, and Thanks for the links so that we can learn more about them! :thumbup:
