ECU flash cost
IdahoMtnSpyder
What price range are we looking at to have a Monster Fuel stage 1 flash done on the 1330? $200, $500, $1000? I'm coming up empty searching for it and don't find a price schedule on Monster Fuel web site. From all I read here and the MF site it sounds like it's a well developed and worthwhile upgrade. I got to thinking maybe it's what I need to get the top end power and torque I wish my RT had when it comes to passing semis at 70+ mph on the Interstates.
I’m with you looking for another boost when I need to pass.
Here's a start for you IdahoMtnSpyder , https://wick-itperformance.com/ and I see where they start at $391.
Thanks. When I got to thinking a bit more I realized the flash is just the first cost. I'm one of those who runs on regular gas, not premium. Monster Fuel pretty much requires you to run 91 octane minimum for Stage 1 flash, so I would have a continuing additional cost for the gas. Of course, if an owner always runs 91 already per BRP recommendation then that's a non-issue for him/her. For Stage 2 flash MF absolutely requires you to run 91. Don't even think of using 87, even in an emergency.
But let's not get into a 91 vs 87 octane debate. That's been :bdh: plenty enough already. If you remember my thread of a year or two ago I had better results with 87, believe it or not!
Me too on the flash. I thought it was about $300.00-$400.00?..ck here:
https://www.monsterfuelinjection.com/
Yeah .. Once the timing parameters are changed in the flash, 87 octane goes out the window. I'm kinda in the same thought process as I'll be purchasing a Dynojet PV3 tomorrow. Nice thing with that is it's easy to flash back to the stock map and nothing is permanent.
Has anyone done a topic that compares a Monster reflash vs Dynojet setup. No true plans to make a change, but others have asked, and sometimes you never know. Maybe I will decide we need to make a change.
I have the stage one and Monster just told me it's $150 to add the stage 2. I'm gonna do it soon. Mike
The biggest drawback with the PV3 is lack of tuners who have the capability to put a Spyder on a dyno to do custom tunes. The PV3 device itself has so much tuning capability. In the two wheel world, the biggest advantage of the Power Vision is getting a custom tune for your specific machine. A custom tune for specific builds is better than a broad brush stroke of maps/flashes made on a specific machine to work on all models. Heck, the ECU flashes are for multiple years/models. Not all machines are created equal. Sure, they're better than nothing, and in most cases work very well. I have used both, but in the end, I prefer the non permanent route. Over time, the map base for the PV3 will improve.
As one of the :spyder2: owners who has taken the leap to the ECU flash-------- it's worth every cent. There is of course the huge smile on your face causing the right wrist to twist just a bit further. nojoke
Lew L
I've not spoken to Wick-It personally, however from comments by those on this site who have, I understand that your flash is done according to a stock set up, or, whatever improvements you've made to your machine. Air filter/air intake, cat still installed/cat delete, muffler stock/straight pipe, and so on. Give Wick-It a call, I'm sure all your questions would be answered, that's their business. As for a "Monster reflash vs Dynojet setup," Google it. There are a number of other motorcycle sites who's members have discussed that very issue in great detail. If you search ECU/flash on this site it'll keep you occupied all day and half the night. Good luck and let us know what you decide.
