BlueKnight
Here's my Sirius setup....
I mounted the base directly to the rear tray in the trunk, used a short right angle stereo adapter with the mp3 adapter to plug into the bike. Plugged the power adapter in and set the antenna right in the middle of the tray.
With this setup you will only be able to control the volume through the handlebar controls. And you have to remember to power off the Sirius radio or unplug it because it will stay on.
As far as reception with the antenna being inside the trunk, I have only tested it once and it worked pretty good.....I will let you know after further testing.
