solidgranite
I went out to start my Spyder RT SE5, and once it was running, I got all kinds of errors flashing at me! Check Engine, ABS Issue, Limp Home, and many more (seemed like all them!). I had ridden it the day before with no problems, so I didn't know what was going on. I shut it down, and checked the usual things...oil, brake fluid, anti-freeze mix, tire pressure, the belt, any foreign objects, etc. I added about 1/4 cup of oil, and a couple of tablespoons of brake fluid, just to top them up. Didn't need any coolant at all... Everything else checked out fine. I turned the key, and started it up...NO ERROR MESSAGES AT ALL! I've ridden it several times since this incident with absolutely no problems or error message, warnings, etc. I have no clue why it went "crazy" that one time. Seems like everything is fine now...runs like it should (and always did). What the **** happened???
