jcthorne
Well-known member
:shocked: Have you ridden a bike yet with the updates? What are you basing this opinion on? :dontknow:
Yes, Louise new RT-S has the update.
The dealer just picked up the Spyder...hoping the ECM flash helps...I've been running really lean.....
And what is it doing for her bike? :dontknow:Yes, Louise new RT-S has the update.
Similar heat problems since new 2012 RS picked up from dealer last May. Already tried all the fixes that normally worked for heat problems. Anyone know whether this new ECM flash will work for the 2012RS?
Before I start to jump up and down I will ride my bike when is 80, I'm taking my bike on Friday to the dealer to get this fix done and I will take it for at least a 2 hour ride, is great that you are not feeling any heat coming from the bike..
It is a '13 only update. Sorry.![]()
It will be interesting to see if you lose any MPG now that it is running richer. If it fixes the heat problem, then I would not care.
Was the fuel sending unit part of an update or recall, or just a customer complaint type fix?
I agree the ECM update helps, but, it does NOT fix the whole problem. The exhaust still badly heats the tank and the fumes are still bad and dangerous.
Or... What was her bike doing, before the update was installed?
base does your dealer have the fuse box covers yet, i told my dealer to order them so i can get everything done at one time
Just a totally different issue that has been haunting me. Think that is fixed now. It was frustrating, but not serious. Warranty covered it. Thank God for my warranty!
