Dyno tune Spyder that already has autotune?????
Generally, what's called 'Dyno tuning' is really just using a device called a dynamometer (or a rolling road) as a tool to measure & 'fine tune' any other method of getting the engine tuning & timing right, & maybe measuring the power change/results of or the calibration of whatever other tuning method you've already applied - effectively, the dyno is just one tool that can be used by the tuner... but it's not actually a 'tune' or tuning method per se or in itself..... so there's generally no really significant benefit from doing or getting a dyno done too if you've already done your tuning or got an 'on the go' tuner that's always updating/changing anyway :lecturef_smilie:
And to add to that, I don't know of too many dyno's that can even be set up to work readily with a 3 wheeled machine that needs the non-driven front wheels to turn at or near the same speed as the driven rear wheel or it'll throw codes & revert to 'Limp Home' mode... effectively defeating the purpose of the devise & negating any benefits you may get by using a 'rolling road' to aid in the tuning process.... Not saying it can't be done, just that it's not easy & since there's not much other benefit to be had anyway.... :dontknow:
Your choice tho - or maybe you could just send me the dollars you'd spend on getting the dyno done - that'd probably do your tune just as much good! Altho a run on a dyno might be able to tell you exactly what power outputs you are getting before & after any other tuning work or mods...... but it won't actually be up to changing much else in itself tho! :thumbup:
