Dry Clutch Rattle
JJRider
Completed my first oil change on our 12 RT-S. With the tupperware off and the oil changed, I started her up and she sounds much different with the plastic off. There was a noise coming from the engine that sounded just like a dry clutch Ducati. Guess I never noticed it when the tupperware was on. Have others heard this sound when the side panels were off?
Thank you!
Don't know..!!
about RT's but our RS makes no such noise. Seeing as they are the same base engine..aah!! but ours is a manual clutch so I can't speak for the semi's...hang in there those who know will be here shortly..!! :thumbup:
Thank you for the comments. To answer the questions, ours is a SM5 and the noise did not ever go away once the oil pressure was up and it was warm. I will take it out this weekend now that I have all the tupperware back on and see if anything is different.
Thank you,
Shake rattle and roll
Hoping your noise is just a normal vibration effect and nothing serious. Usually when I think rattle I start looking for loose heat guards and such. An old trick is to take a stick, broom handle works, place one end on the machine at various points and the other at your ear. You can isolate noises well with this. I have a stethoscope with a long metal rod attached to the pickup and this works wonders in listening to an engine to diagnose problems. Good luck!
