I'm not sure i understand what the belt is doing, your first post says the belt is moving in and out, do you mean it's slowly moving back and forth and not holding the line where you set it or is it one spot that seems to jump that far out. Is this with the rear off the ground and running in gear? What did they reset the tension to with their tester, is it still 160 on the kriket? Do you feel or notice this while riding since they worked on it, or could it have been doing this before. What was the rear brake doing that made you take it in, i do tend to ride mine a bit when I'm downshifting. All i know is that whenever i've let a dealer do something, i often find something else has changed, the ride has changed, sounds different, just not the same. Mine had never been to the shop until the DPS recall, i said just fix the steering, nothing else!, when i went to pick it up they scolded me and said i need to maintain it better, the oil was 1.5 qts low, the coolant was low in the tank, all clumpy and smelly and i should change it right away, but they topped everything up for me. Well, i about ran the battery down restarting it trying to get my gauge cluster set like i had it, so i went the long way home to recharge it and check out my new steering, many miles over 100mph. Checked the oil when i got home, overfilled 1.5 qts., glad i have a drysump system, drained all the coolant out the next day, it was green and clear like new, just sayin! I had even stuffed a $20 in the mechanics shirt before i left and said "thanks for taking care of me". Of course all dealers aren't the same, and we must depend on them for some things we can't do, but i always like to check the basics before i take it in and when i get it back. Hope they get you squared away.
