Drive belt problem...not good
killerbee
Have to cancel all of Spyderfest. Dealer has to pull motor, replace sprocket, etc. etc., etc. Wondering if Canada has the lemon law at this point.:mad:
Very sorry to hear this. Yet another. I'm not getting a good feeling from my drive line these days either. There is a noise developing from what sounds like the tranny. It's a high pitch whine that was not there before. What were your symptoms?
Sorry to hear of the troubles. As you may or may not know, BRP released information last year suggesting a re-torque with new torque settings for the front sprocket on the Spyder RS/GS and RT.
Not sure of the problem you are seeing here, but it may be worth your while to see if the Dealer had performed or was asked/instructed to perform this maintenance.
More information on this can be found here, in the hopes that it will help:
http://www.spyderlovers.com/forums/showthread.php?t=18252&highlight=sprocket
Cheers and I hope all works out as good as possible.
May just be the belt is too tight. I had a whine from mine when I got it until I adjusted the belt to the new spec.
Thanks for the info Sam. Not sure what the situation was for Killer Bee, but in my case, unfortunately, I just had tires put on and a drive line service performed not even 2 months ago. That was @ 11,000. We are now @ 13K. It'll have to go back at some point very soon for another look, but I don't have a good feeling about this... :shocked:
:dontknow:
Shot in the dark here, Check to see if your belt is rubbing against the rear sprocket flange,
If it is that will cause an annoying whine.
Very good suggestions. I had a problem after the belt had been adjusted to the new tension. Keep an eye out for any oil leaks on the left side of the engine "around the drive sprocket area".:yikes: Hope it is just the belt out of alignment or something else simple.:clap: Luckily we were near a dealer that knew what they were doing(Rice Honda in Rapid City, SD:bowdown:) and got us back on the road on the way home, 1100 miles away. Carlo with BRP Customer Service was fantastic and helped us to keep our sanity:clap::2thumbs:
Ohio Lemon Law
Revised Code, 1345.71 to 1345.77
Motorcycles are covered​
3 unsuccessful repairs of same defect or 30 calendar days out of service or 8 total repairs of any defects or 1 unsuccessful repair of problem likely to cause death or serious bodily, injury within shorter of 1 year or 18,000 miles. Leased vehicles covered. Consumer does not have to be original owner.​
My front sprocket and belt have been replaced as well, and luckily we caught it before any engine damage was done. Mine developed a very high pitched whine, and it was rubbing against the outer flange of the front pulley. I have a thread on here about it: http://www.spyderlovers.com/forums/showthread.php?t=25425
BRP will take care of this issue under warranty, and since it is the first occurence there will not be any reason to attempt to look into lemon laws. Let them figure out what went wrong and get it fixed for you. It does suck that you will be missing Spyderfest because of it. Hopefully they will get you back on the road soon. Best of luck.
