DPS limp home mode check engine
78OldRide
All 3 came on going to work this morning. Went out later to start and check codes. Engine sound like it was going to fall apart. Throttle body not closing properly. I have BEST called dealer and will be taking it in today. I will up date once it is out of shop.
Bummer...
Did you pull any codes..?? I see from your profile you are on a 2011 RT. Now that it is off to the dealer we will wait to see what they find...:gaah::popcorn:
This is on your 2011? :dontknow:
Pull up your error codes, the next time it does this: I'm betting that it's the throttle bodies... :banghead:
bad gas
Got the bike back I had just filled up with gas and rode about ten miles. Thats when it hit the fan. Dealer drained gas and said it was almost clear and did not have a strong gas odor. Plugs were replaced fouled out. Some new buds updates . It was raining heavy so picked it up on trailer hope to ride some this week endto check it out.
As on my RS-S the boots under the throttle body cracked and had to be replaced but I could not tell until the dealer checked... :yikes::gaah: good luck jtpollock
