bumper60651
I've had problems with my DPS in the recent months and have taken it into the dealer to find out what is wrong.  The DPS works intermittently and didn't throw a fault code before I took it in this last month.  The dealer mechanic adjusted some of the sensors and when I got it back home my turn signal cancellation sensor was out of whack.  So this past weekend I was scheduled to go on a poker run and only made it as far as 15 mile north of my home before I got a check engine signal on my instrument panel.  I thought I could make it to the next rest area when I went into Limp Mode with a fault code of VSS.  I got into the rest area, turned it off and everything seemed alright until another 5 miles north when I received another fault code of DPS.  Again I went into Limp Mode and decided to turn back toward home.  This happened again on my return to home and again I pulled off the side of the road, shut down and restarted the engine with no codes.
I'll be taking it back to the dealer this week and hopefully getting the DPS to correct itself. The first time I was there, I didn't have any fault codes; now this time I do and the dealer tells me he doesn't think he can get it back to me within a week. I'm planning on taking it with me on an annual camping trip on Oct. 2. Any ideas as to what is happening with the DPS at this point? I've gone in and re-tightened the leads on the battery thinking maybe there was a short but they weren't too loose. Anything you can supply me with before I go back to the dealer (a two hour drive) as I trailer it since I never know how long they're going to keep it and I don't want to be stuck in Bakersfield for a week. Thanks in advance for you help...
