Grandpot
If you have ever lost a side cover, you will find that they are very expensive, $300. That's considering you had to replace the Can Am badge and sound proofing.
In the pictures, you will see I drilled a hole in the cover and placed a 6mm fender nut on the lip underneath. Attach with a 6mm Torx screw so it looks like OEM. This is a very secure setup.
Some folks have suggested tethering the cover, but that's not such a great idea. If the cover comes off a 60 MPH, then the cover will be flopping in the wind and flailing everything around it.
Don't forget to put a Torx wrench in the glove box so you can get the cover off when you need to.
