Fusionfool
Rear Trunk Cigarertte Plug (Battery Tender)
Remember Battery tender lighting will let you know if there is any issues. Blinking Red means bad connection, Solid Red means charging below 80%, and blinking Green means charging above 80%, solid green means charged and maintaining when needed.
I have not had any problems. Tender always shows solid green after about 15 minutes or so.:thumbup:My tender gives me the option to either connect directly to the terminals with clips ( as recommended in the owner's manual ) or, use the cigarette lighter in the rear trunk.
I've been connecting to the terminals. Only because the maunual recommended this method.
Is the cigarette plug just as good? Sure would be easier.
