Does your 2020 F3-S Special Volume Rocker switch work?
Bearcat
Can anyone with a 2020 F3-S Special (with BRP Connect Dash) confirm if their volume rocker functions?
I have sound going to my Cardo Pactalk headset in my helmet. Its a great set up.
I am able to control volume with the joystick just fine, but I don't think the dedicated volume rocker has ever done anything for me. It is a bit maddening, I have found that the only way to edit volume is to exit BRP connect and use the joystick, when there is a volume switch right there in front of me! It also took me a long time to figure out that the notification volume- for Genius Maps turn by turn- cannot be changed while in Genius Maps! You have to exit BRP Connect in order to edit that volume in the brief window where you are receiving notifications. I would like to know if my volume rocker is broken, or if it (by design) just doesn't do anything.
It looks like the F3-S non special doesn't have the volume rocker at all. Has anyone utilized this space for anything? Controls for heated grips would be a great use of the space.
Thanks for the help. Thats odd that they bothered to add the button without connecting it to anything.
I don't think it was so much 'add the button' as it was 'fail to remove the button!!' Don'tcha know there's time & effort & therefore cost involved in popping out that button & replacing it with a blanking plate! :p :rolleyes:
That said, I reckon it might be worth having a look underneath that rocker button - sure, your model might not have all the features the other models have, but if BRP follows their established form, there's a good chance the wiring loom & plugs etc to connect it up are all there too - the question is, will connecting them allow you to do anything?! :dontknow:
On just about every other Spyder/Ryker model, those 'not used' buttons &/or blanks still have all the connectors & loom, plugs etc in place underneath; and in some cases (F3 cruise control for example) it's just a matter of getting/installing the correct switch/control unit to do a DIY upgrade on your machine! :ohyea:
Might be worth a shot?? :thumbup:
Did anyone ever figure this out? I would love to use the wiring loom inside of this space if I can find where the other end is hanging in the dash or maybe even use it as a volume control itself.
