Does using a cat delete help with seat heat?
Fitting a Cat Eliminator has to reduce under-body heat, simply because Cat Converters are heat generators, designed to generate sufficient heat to get the catalyst honeycomb up to at least 600°C before it'll do anything in the way of 'catalysing' any exhaust gases! :cautious: So if you remove that heat generator, you WILL reduce a significant amount of the heat generated and radiated immediately underneath the bodywork, engine, and seat; and instead, you see most of that potential heat get blown out the back with the rest of the exhaust, somewhere which means that heat cannot spread/radiate into the rest of the Spyder. ;)
As to how much heat that'll actually reduce in your seat, &/or how much it'll 'help with seat heat', your guess is as good as mine, I've never bothered to measure it, and I have no idea what might be causing your particular seat heat issues. :unsure:
BUT, I can tell you from my own personal experience that on my 2013 RT, fitting a Cat Eliminator certainly helped reduce MY seat heat issues! (y)
I know this, because BEFORE the Heat Minimisation Recall came out & was fitted to my 2013 RT, and before I took off the Catalytic Converter & installed a Cat Eliminator, on a warm day, besides the blast of hot air from the Dragon's Mouth RHS radiator vent onto my Right Shin, I simply could not sit on the seat while riding for anything much longer than about an hour, hour & a half at most, before the seat became too hot and besides my butt, certain other more sensitive parts of my anatomy became VERY CONCERNED for their future ability to function/contribute any further to the gene pool!! And every other (male) rider who rode my Spyder for any length of time complained of similar anatomy cooking issues. :eek:
Yet AFTER I fitted the Cat Eliminator, and still before the Heat Minimisation Recall came out & was fitted, I (and others) could easily and comfortably ride all day on that same seat because it simply didn't get anywhere near as hot - and at that stage, the only thing that'd been changed was fitting the Cat Eliminator instead of a heat generating Cat Converter. :sneaky:
So for ME, yes, fitting a Cat Eliminator certainly CAN & DID help reduce Seat Heat! YMMV, but it made a BIIIG difference for me/my Spyder seat! 👏
Just sayin' ;)
If you think the seats getting too much heat from, below, get some of the heatshield mat guy's use on car fire walls and floor boards when your doing a resto! It's thin and has a sticky backer and will reflect the heat back down and keep it maybe cooler than it is now!
I might have felt a little reduction in seat heat, but I also ride a Road King so a hot seat is something I'm used to... :p What I really noticed was much less heat coming out from under my F3T and the lack of burning rubber smell when I parked in the garage. That was enough for me. The bonus was when my boss at the time remarked that my Spyder now sounded like a race car.
