Does f3 need buds
r1100rider
Does f3 need buds to reset check engine display even though there are no active codes and can oil overfil cause check engine code , 9miles 10 min idled then 2 min just to check oil level who thought of this ,oil level check is a 20 minute job
Most codes will change their state from active to occured themselves, when the problem has been fixed. There are only maybe 1 or 2 that require being connected to buds to reset. If the display says check engine. There are active codes.
Why do you make it sound so difficult to check the oil level. It's not. When arriving home after having a fun ride. About once a month, depending on mileage. Check the oil. How hard is that? Really only takes a couple minutes. If the oil level is between the add and full, it's fine. It does not have to be full. It is normal that you will not have to add any oil between oil changes.
Yes overfilling with oil is bad. Don't know if it will cause any codes.
the display says no active codes when you put it in the code read mode ,the bike only has 30 miles on it and the oil is clean so it's very hard to tell level I just quoted the check process as listed in book and cover panel
If it only has 30 miles on it. Call the dealer.
Obviously an active fault yet it does not display on the active fault screen. That has come up a couple times lately and is not suppose to happen. No explanation for this so far either.
Dealer is 3 hour drive I was hoping for something simple as overfilled oil thanks for the reply
The 10 min idle is only needed if you have not driven the Spyder long/far enough to bring the oil up to operating temperature. I like to do a 20 mile loop to ensure that it is + it's more fun than idleing!.
