I actually used mine today (one of a few times since I have owned the bike). Yes, it does affect the throttling. For that reason, I will not use it in traffic because it doesn't have the acceleration that I would like to have when needing to get out of peoples way, or avoiding others. It is suppose to help with mph, but I am not sure how much it will help. I did 217 miles today and averaged 37.5 mph. Not as good as my M109, but a lot better than the lightnings 15 mph.Is the ECO mode on the 14s nothing more than a reminder on the screen? Seems like I read somewhere that it actually affects throttling. Is that true?
this "mode", does put in a different "map", that softens throttle response, especially below 4 thousand rpm. Above that rpm, I really can't tell the difference.
As for the dreaded shift arrow, I can't read anything in the display anyway, so I ignore it..
I use ECo mode usually, because I don't really need everything the 1330 can give me at a traffic light, it's just more casual, and I think it makes e-shifter more gentle.
I have seen throttle response curves from BRP published on this very website and at least for the 2014 RT, it does indeed affect throttle response and power throughout the whole RPM range. It reduces the response by what looked to me like about one third. The behavior of ECO mode is also briefly explained in the owner's manual. You have to physically turn this mode off. It does not detect the rider's intentions on hard acceleration. I have experimented with ECO mode and fuel economy. My conclusion is that you get better mileage using ECO mode than regular mode, even if you take it really easy in regular mode. My personal opinion is that even with only 2/3 of the available power, the Spyder will still easily out-accelerate most cars in ECO mode and is not at all unsafe. I don't normally use ECO mode because I like strong performance and I didn't buy a Spyder to get good gas mileage. I guess I want to act like a hooligan every once in a while as JayBros says. :roflblack::2thumbs: I just did all this research and experimentation because I was curious.
Please read post #5 from Lamont on this subject http://www.spyderlovers.com/forums/showthread.php?61713-Eco-Mode-and-Shifting-RPM
i shift by ear, does anyone else go by engine sound and not rpm
