Does anyone know if the BRP hitch on my 2010 RT...
BigGuy66
... will fit on the (NEW) 2019 RT Limited we are considering to buy? Hate to spend another bunch of $$$ for another hitch. What about removal? Can a reasonably competent handy guy remove the hitch and get the belt and tire back where it needs to be? Trying to save some $$$ again. Thanks -
Jim
The physical hitch will fit but you will need a new wiring setup specifically for your new ride
Removal is very simple and no need to remove belt or tire.
Cruzr joe
Easy job to get it off. All you do is pull the axle out. No need to remove belt or wheel or change anything else. Just pay attention to the spacers or shims that might be in place. You might need to get a replacement harness, but you're still waaay ahead doing it yourself. You can find videos of most anything on YouTube
Here are the instructions for installing a hitch, reverse the process for removal. I'm using this link as a reference for the hitch removal only not the wiring. https://instructions.brp.com/content/instruction-sheet/en_CA/e-instruction-details.html#googtrans(en)&articleNo=kA00c000000smGKCAY&lang=en&title=ROADSTER%20KIT%20-%20Trailer%20Hitch%20Spyder%20RT&rel_part_number=219400854
Is the connector on your trailer the 9 pin round or 4 pin square? This will make a difference in your wiring setup.
My wiring is actual a 5-pin flat for my Bunkhouse camper.
One question ... I bought a 2017 RTL used that has the BRP hitch on it. I removed the long center bolt and the hitch, as I don't see us using it. It appears as though the long center bolt is only installed with the hitch, and there is no need for one without it. The long center bolt is too long to reinstall without the hitch ...
Just making sure it did not come with a shorter one prior to the hitch install.
Thanks,
Doug
No you do not need the center bolt. The bolt is part of the hitch. After you remove the hitch you replace the plastic caps in to the hollow axle if you still have them
That is what I thought ... always good to ask when the rear axle is concerned!
No plastic plugs, I'll try to pick some up sometime.
Thanks,
Doug
Thanks,
Doug
Are you looking to sale that hitch as I may be interested. Not sure about shipping as I see your in Nova Scotia, might make it cost prohibitive. Let me know.
Thanks,
Chris
